Knowledge Base Article
Why do I see a Qsys warning for the pll_sharing conduit even when the PLL sharing mode option is set to 'No Sharing' in the UniPHY Megacore settings?
Description
The pll_sharing conduit is exposed in Qsys even when the UniPHY Megacore's PLL sharing mode is set to 'No Sharing'. This will cause Qsys to issue a warning "**_pll_sharing must be exported, or connected to a matching conduit." The pll_sharing conduit is forced to be exposed because users need access to the pll_locked signal.
Resolution
Users may ignore this warning as it will not affect Qsys generation.
This warning will be fixed in a future version of Quartus® II software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
