Knowledge Base Article
Why do I get this error "Error (210039): File SOF/<project_name>.sof contains one or more time-limited IPs that support the Intel FPGA IP Evaluation Mode feature that will not work after the hardware evaluation time expires."
Description
The error 213009 might be seen in the Intel® Quartus® Prime Pro Edition Software version 22.4 (and earlier) when the user is using an IP for which the license is missing.
Resolution
To resolve this problem in the Intel® Quartus® Prime Pro Edition Software version 22.4, follow these steps:
1. Ensure you update and have a proper license setup for IP in your design.
2. If you updated your license and the error persists, ensure the project is fully recompiled and the Platform Designer system is completely re-generated.
Updated 2 months ago
