Knowledge Base Article
Why do I get error message when I change IO termination value with UniPHY memory controller ?
Description
UniPHY based IP has only one OCT controller block, thus changing the OCT termination value from 50 Ohm to 25 Ohm for a specific signal will generate the following error message:
Error (174043): I/O "pin_name" is driven by on-chip termination control block "{hierarchy_path}:uoct_control|sd1a_0" but has a termination value which conflicts with other I/Os driven by that control block.
Resolution
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
