Knowledge Base Article
Why do I get "Error (21596): Target device at device index 1 does not support CONFIG status report.​" when I try to run the configuration status report using the quartus_pgm command?
Description
In Quartus® Prime Pro Edition Software version 23.2, the quartus_pgm command line to check the configuration status is not working. ​
quartus_pgm -c <cable> -mjtag –status​
Resolution
To work around this problem, you may try to perform below steps:
  • Option 1: Use the Configuration Debugger Tool to check the configuration status. Refer to AN 955: Programmer’s Configuration Debugger Tool on how to use the tool.​
  • Option 2: Send the SDM mailbox command CONFIG_STATUS [0x4] to check the configuration status. Refer to Agilex™ 7/Stratix 10 Configuration User Guide and Mailbox Client FPGA IP User Guide for more information about the CONFIG_STATUS command.
quartus_pgm -c <cable> -m jtag --cmd_code=0x4​
This problem is already fixed in Quartus® Prime Pro Edition Software version 23.3.​
Updated 11 months ago
Version 3.0
