Knowledge Base Article
Why do I get Burst Chop when accesing DDR3 SDRAM using Altmemphy based DDR3 SDRAM Controller?
Description
You will see burst chop when accessing DDR3 SDRAM using Altmemphy based Controller if local_size is set to 1. When local_size=1 ,you will not get Burst Length (BL) of 8 for consecutive addresses, but only Burst chop. If you need BL of 8 to improve the efficiency, you need to enable burst merge option.
Burst merge was introduced as option in controller setting tab of Altmemphy based DDR3 SDRAM Controller in the Quartus® II design software 10.1.
Burst Merge option will be added in UniPHY based DDR3 SDRAM Controller in the future version of the IP.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
