Knowledge Base Article
Why do I get an error message when compiling my design targeting Arria V Hard IP for PCI Express in Quartus II software versions 11.1 and 11.1 SP1?
Description
Due to a problem in the Quartus® II software versions 11.1 and 11.1 SP1, when implementing a design with an Arria® V Hard IP for PCI Express® core with the BAR1 set to 32-bit in the Megawizard™, you may see an error message similar to the one below.
Error: Hard IP parameter \'hd_altpe2_hip_top_bar1_prefetchable_0\' is set to an illegal value of \'false\' on node \'top:inst|altpcie_av_hip_ast_hwtcl:top_inst|altpcie_av_hip_128bit_atom:altpcie_av_hip_128bit_atom|g_pcie_hip.arriav_hd_altpe2_hip_top\'.
       Info: No legal values found
Resolution
To work around this problem, download and install the appropriate patch from the links below:
For the Quartus II software version 11.1
Download the version 11.1 Patch 0.19 for Windows (.exe)
Download the version 11.1 Patch 0.19 for Linux (.tar)
Download the Readme file for Quartus II software version 11.1 Patch 0.19 (.txt)
For the Quartus II software version 11.1 SP1
Download the version 11.1 SP1 Patch 1.07 for Windows (.exe)
Download the version 11.1 SP1 Patch 1.07 for Linux (.tar)
Download the Readme file for Quartus II software version 11.1 SP1 Patch 1.07 (.txt)
This problem is scheduled to be fixed in a future version of the Quartus II software.
Updated 4 months ago
Version 5.0
