Knowledge Base Article
Why did the Quartus II software not preserve my updated ALTPLL megafunction parameters after I migrated my design from a different version of the Quartus II software?
Description
If you migrate from one version of the Quartus® II software to another version, the files in the /db folder will not be updated if you make changes to the PLL settings in the ALTPLL megafunction. In order for your changes to take affect, you need to delete both /db and /incremental_db folders in your project directory, then regenerate the ALTPLL megafunction for your design.
You can verify the changes are correct by looking at the PLL Usage Panel in the Compilation Report => Fitter => Resource Section.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
