Knowledge Base Article
Why certain I/O pins are pulled to LOW during POF programming for Intel® MAX® 10 devices with U324 package ?
Description
In Intel® MAX® 10 devices with package U324, some of the I/O pins are getting pulled to GND after the speed mode SOF file is being configured into the device.
User will observes that certain I/Os are being pulled to LOW instead of being tri-stated during POF file programming into the internal flash using Intel® Quartus® Prime Programmer.
This is due to the speed mode SOF file is not compatible with the new Ordering Part Number (OPN).
Resolution
User can apply a patch (for Intel® Quartus® Prime 20.1 Standard Edition) to correct the corresponding I/O state to tri-state. Alternatively, user can execute the POF file programming without speed mode selection (enabling real-time ISP in Intel® Quartus® Prime Programmer).
Download the patch 20.1std-0.09std-windows for Windows (.exe)
Download the patch 20.1std-0.09std-linux for Linux (.run) ( https://www.intel.com/content/dam/altera-www/global/en_US/support/knowledge-center/components/2020/quartus-20.1std-0.09std-linux.run)
Download the Readme for patch 20.1std-0.09std-readme (.txt)
This is a known issue affecting all version prior to Intel® Quartus® Prime Pro Edition 20.3 and Intel® Quartus® Prime Standard Edition 20.1.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition software version 20.4 and Intel® Quartus® Prime Standard Edition software version 21.1.
