Knowledge Base Article
Why can't the Quartus® II software automatically merge the Transceiver Avalon Memory-Mapped interfaces of a CDR/CMU PLL and a TX-only channel, of an Intel® Arria® 10 device?
Description
The Quartus® II software does not support Transceiver Avalon® Memory-Mapped interface auto-merging in Intel® Arria® 10 devices. You may encounter fitter errors if your design contains a CDR/CMU PLL and a TX-only channel, which can be merged and placed into one transceiver channel. By default, a CDR/CMU PLL and a TX-only channel are mapped to two different transceiver channels.
Resolution
To work around this problem, add the following assignment to your Quartus® II Settings File (.qsf):
set_instance_assignment -name XCVR_RECONFIG_GROUP MERGE_TX_CDR_PLL -to "TX_Serial_Pin_Name"
set_instance_assignment -name XCVR_RECONFIG_GROUP MERGE_TX_CDR_PLL -to " <CDR/CMU PLL variation name>|altera_xcvr_cdr_pll_a10:xcvr_cdr_pll_a10_0|twentynm_xcvr_avmm:inst_twentynm_xcvr_avmm|avmm_atom_insts[0].twentynm_hssi_avmm_if_inst"
set_instance_assignment -name XCVR_RECONFIG_GROUP MERGE_TX_ CDR_PLL -to " <CDR/CMU PLL variation name>|*"
Updated 2 months ago
Version 2.0
