Knowledge Base Article
Why can't I use the Examine feature using command-line executable quartus_pgm to read back a JTAG Indirect Configuration File (.jic)/ Programmer Object File (.pof)?
Description
Due to a known issue in the Quartus® Prime software version 16.0.2 or earlier, the Examine feature using quartus_pgm for the .jic/.pof may be ignored. An example of the command is below.
quartus_pgm -o ei;file.jic;device_name
Resolution
To work around this problem, perform the following actions.
- Prepare the Quartus Prime Programmer GUI environment.
- Save the Chain Description File (.cdf) file in the Programmer GUI before starting examine and after checking the check-box of Examine. (For example, save as file.cdf.)
- Edit the arguments of Path() and File() in file.cdf as necessary. (The argument File () should be the temporary .jic/.pof which is overwritten.
- Execute quartus_pgm file.cdf in command-line.
This problem is scheduled to be fixed in a future release of the Quartus Prime software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
