Knowledge Base Article
Why can't I run Nios® II Software Build Tools (SBT) Eclipse in Intel® Quartus® Prime Pro Edition 20.1?
Description
Due to an issue with directory and file permissions, users will encounter a Permission denied error when running Nios® II SBT Eclipse (eclipse-nios2 command) from the Nios II Command Shell .
Resolution
To allow other users to access Nios® II SBT Eclipse run the following commands to set the correct permissions before installing Eclipse  Nios® II plugins:
  • export CWD=/nios2eds/bin        #setting an environment variable $cwd for the current working directory
  • mkdir $CWD/temp_dir        #creating a temporary directory for changing file permissions
  • tar xf $CWD/eclipse_nios2_plugins.tar.gz -C $CWD/temp_dir          #un-archive to the temporary directory
  • chmod g rwx,o rx $(find $CWD/temp_dir/eclipse_nios2 -type d)    #updating correct permission bits for directories
  • chmod g rw,o r $(find $CWD/temp_dir/eclipse_nios2 -type f)          #updating correct permission bits for files
  • cp -rpf $CWD/temp_dir/eclipse_nios2 $CWD                                         #overwrite with the updated eclipse_nios2 folder
  • rm -rf $CWD/temp_dir        #remove temporary directory
  • unset CWD        #un-setting the environment variable
Updated 2 months ago
Version 2.0
