Knowledge Base Article
Why can't I meet the target impedance when entering 0mA into the PDN Tool?
Description
In the Power Distribution Network (PDN) tool, you may not be able to meet the target impendence when entering 0mA into the tool.
If low current power supply pin types like VCCBAT are set to 0mA, a high effective impedance will be calculated. Other power supply pin types may also show this problem.
The minimum allowable non-zero current entry into the PDN Tool is 0.001A. If 0A is entered into the Intel® PDN tool for a current value below 0.001A, the tool encounters a divide or multiply by zero error.
Resolution
To work around this problem, you can enter 0.001A to calculate decoupling for currents less than 0.001A. Entering 0.001A will not significantly burden your decoupling solution.
Updated 11 months ago
Version 3.0
