Knowledge Base Article
Why are the PCIe Hard IP SDC constraints for tl_cfg* ignored in my SOPC Builder design?
Description
The PCI Express HardIP constraints for signals tl_cfg* are ignored in the SOPC Builder designs because the altpcierd_tl_cfg_sample module is not used in this mode.
As a result, in pcie_compiler_0.sdc, the SDC constraints that are placed after the comment below will be ignored:
# The following multicycle path constraints are only valid if the logic use to sample the tl_cfg_ctl and tl_cfg_sts signals
Note: These constraints are valid in the Platform Designer and Avalon® streaming HardIP configurations.
Resolution
N/A
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
