Knowledge Base Article
Why are multiple instances of a selected word copied and pasted when using shortcut key Ctrl C / Ctrl V?
Description
Due to a problem in the Intel® Quartus® Prime Standard Edition Software version 21.1, you may see this problem when using the shortcut key combination Ctrl C / Ctrl V to copy and paste in the Text Editor.
Resolution
To work around this problem, use the shortcut key combination Ctrl + Insert / Shift  + Insert to copy and paste.
This problem is fixed starting with the Intel® Quartus® Prime Standard Edition Software version 22.1.
Updated 11 months ago
Version 3.0
