Knowledge Base Article
Why am I missing some icons in Signal Tap when using the Quartus® Prime Pro Edition Software version 18.0?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 18.0, you may see some missing icons in the Signal Tap Logic Analyzer GUI. This problem occurs when installing the stand-alone programmer for the Quartus® Prime Pro Edition Software version 18.0.
Resolution
To work around this problem, for the Quartus® Prime Pro Edition Software version 18.0, download and install patch 0.25 from the links below. You must install the Quartus® Prime Pro Edition Software version 18.0 before installing this patch.
Download the version 18.0 patch 0.25 for Windows (.exe)
Download the version 18.0 patch 0.25 for Linux (.run)
Download the Readme for the Quartus Prime Pro edition software version 18.0 patch 0.25 (.txt)
This problem is fixed beginning with version 18.1 of the Quartus® Prime Pro Edition software version.
Updated 4 months ago
Version 4.0
