Knowledge Base Article
What transceiver slew rate settings are allowed in the Quartus II software for Stratix V GX and Arria V GZ devices?
Description
The following transceiver slew rate settings are allowed in the Quartus® II software for Stratix® V GX and Arria® V GZ devices.
Protocol/Datarate Allowed Quartus II Setting IBIS-AMI Setting
PCI Express Gen3, Gen2, CEI
4*_30ps
PCI Express Gen1, XAUI3*_50ps
Gigabit Ethernet1*_160ps
=<1Gbps1, 2, 3*_160ps, *_90ps, *_50ps
1Gbps - 3Gbps2, 3*_90ps, *_50ps
>3Gbps - 6Gbps3, 4*_50ps, *_30ps
>6Gbps4, 5*_30ps, *_15ps
Assigning an invalid slew rate will result in an error message similar to the one below.
Error (15001): Assignment XCVR_TX_SLEW_RATE_CTRL of value "4" conflicts with the valid values of the parameter "pm_tx_slew_rate_ctrl"
  • Protocol declarations take priority over datarate. For example, XAUI has a per-lane datarate of 3.125 Gbps, but only a setting of "3" is allowed. A setting of "4" is not allowed for XAUI.
  • For protocols not listed in the table, you should use the slew settings associated with your datarate.
  • The IBIS-AMI slew rate figure is defined as the approximate transmitter 20% - 80% rise time. The "ps" figure should not be considered quantitative and is an approximate label only.
  • The IBIS-AMI models will allow you to simulate any slew rate setting for any datarate or protocol.
Related Articles
Updated 2 months ago
Version 2.0
