Knowledge Base Article
What are the valid bits of the reconfiguration address bus to specify the selected channel when enabling the "Share reconfiguration Interface" option for the Transceiver Native PHY Arria® 10 FPGA/Cyclone® 10 GX FPGA IP
Description
Due to a problem in the Transceiver Native PHY Arria® 10 FPGA/Cyclone® 10 GX FPGA IP information window, when enabling the "Share reconfiguration Interface" option,  there is an incorrect message that upper[n:9] address bits of the reconfiguration address bus specifies the selected channel.
According to the Arria® 10 Transceiver PHY User Guide, when you turn on the "Share reconfiguration Interface" option, the Transceiver Native PHY IP presents a single Avalon memory-mapped interface slave interface for dynamic reconfiguration for all channels. In this configuration, the upper [N-1:10] bits of the reconfiguration address bus specify the selected channel. The channel numbers N are binary encoded.
Address bits [9:0] provide the register offset address within the reconfiguration space for a channel.
Resolution
Updated 3 months ago
Version 6.0
