Knowledge Base Article
Warning: xxx.xcvr_native_a10_0: The current value "1_1V" for parameter "VCCR_GXB and VCCT_GXB supply voltage for the Transceiver" (anlg_voltage) is invalid. Possible valid values are: "1_0V" "0_9V".
Description
Warning message:
Warning: xxx.xcvr_native_a10_0: The current value "1_1V" for parameter "VCCR_GXB and VCCT_GXB supply voltage for the Transceiver" (anlg_voltage) is invalid. Possible valid values are: "1_0V" "0_9V".  The parameter value is invalid under these current parameter settings:  "device" (device)="" (10AX115S4F45I3SGE2). Rule(s): pma_rx_buf_power_mode: pma_tx_buf_power_mode: pma_rx_buf_power_mode_rx.
You may see the above warning when migrating the Arria® 10 device transceiver Native PHY from Quartus® II version 15.0.2 to Quartus Prime version15.1.
If you open the Arria 10 Native PHY IP, there are two new options for the transceiver
1) VCCR_GXB and VCCT_GXB Voltage
2) Transceiver Link Type
These default to 1_1v and Short Reach (SR) respectively.
You should check your board voltage settings and match this to the VCCR_GXB and VCCT_GXB voltage setting in the Native PHY IP. Also select SR or Long Reach (LR) in the Native PHY IP depending on your protocol requirements.
Updated 11 months ago
Version 3.0
