Knowledge Base Article
Warning Message: 'pragma_reverse_bitfields' attribute directive ignored
Description
The Nios II GCC 4 tool chain does not support the C compiler
pragma and flag for reverse bit fields. If you try to use the compiler
pragma reverse_bitfields, you see the following warning:
Similarly, the C compiler flag -mreverse-bitfields is
unsupported.
Resolution
Use the GCC 3 tool chain.
Updated 1 month ago
