Knowledge Base Article
Warning (332060): Node: <Path>|csr_control_data_reg[0] was determined to be a clock but was found without an associated clock assignment.
Description
Due to a limitation in the Intel® Quartus® Prime Pro and Standard Edition Software, you may see the register "csr_control_data_reg [0]" in the ASMI Parallel II Intel® FPGA IP is reported as a unconstrainted clock when using an Intel® Arria® 10 device or an Intel® Cyclone® 10 GX device.
Resolution
This warning can be safely ignored, "csr_control_data_reg [0]" is not a clock.
Related Articles
Updated 2 months ago
