Knowledge Base Article
Variable Casting Unsupported in ISS
Description
Casting variables in the Variables view in the Debug perspective when using the Nios II ISS might cause an exception dialog box to open.
This exception might occur if you select Debug as ISS in the Nios II IDE and try to cast variables via the Variables view.
Resolution
There is no workaround.
Updated 29 days ago
Version 2.0
