Knowledge Base Article
Unsupported OCT enable size values for Arria® 10 Altera PHYLite
Description
When simulating the Arria® 10 PHYLite IP, the same delay is observed with the OCT enable size parameter set to a value of 5, 6, or 7.Resolution
The OCT enable size parameter setting can support values 0-4. Values 5-7 are not supported and will default back to 4 as will be seen in simulation.
This issue will be fix in a future release of the Quartus® Prime software.
Updated 2 months ago
