Knowledge Base Article
TX PLL clock port labelling error in the Arria V Transceiver Native PHY IP core megafunction
Description
If you create an Arria V Transceiver Native PHY IP core megafunction in the MegaWizard Plug-In Manager and you enable the Use external TX PLL option to expose the ext_pll_clk port to an external transmitter (TX) phase-locked loop (PLL), both ext_pll_clk and tx_pll_refclk ports appear in the block diagram but only the ext_pll_clk port is used in the IP core.
Resolution
There is no workaround.
Updated 11 months ago
Version 3.0
