Knowledge Base Article
Turn On Generate Display Port Output Option in the Clocked Video Output II IP Core For External Synchronization
Description
When you configure the Clocked Video Output II IP core to be used with external synchronizations, you must set the Generate Display Port Output parameter to 1. This mode is compatible for Display Port, HDMI, or any other separate synchronization standards.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
