Knowledge Base Article
Transmit Data Error in 1000BASE-X/SGMII PCS
Description
This errata affects the Triple-Speed Ethernet MegaCore function.
When the 1000BASE-X/SGMII PCS function operates in SGMII mode, the transmit buffer may overflow and cause data error.
This issue affects the following MAC variations:
10/100/1000 Mbps Ethernet MAC with 1000BASE-X/SGMII PCS in SGMII mode.1000BASE-X/SGMII PCS only in SGMII mode.
Resolution
This issue has no workaround.This issue is fixed in version 11.1 of the Triple-Speed Ethernet MegaCore function.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
