Knowledge Base Article
The backspace key does not function correctly in the Key box of the SOF File Properties: Bitstream Encryption - Key Entry dialog box
Description
In the Key box of the SOF File Properties:Bitstream Encryption - Key Entry dialog box, the backspace key does not function correctly. Instead of deleting the last character in the box, it deletes the second-to-last character.
Resolution
Use the Clear button at the bottom of the dialog box, and then re-type the entry into the Key box.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
