Knowledge Base Article
Stratix V and Arria V GZ Hard IP for PCIe RX Burst Master May Return Completions with Incorrect Traffic Class
Description
The Stratix V and Arria V GZ Hard IP for PCIe RX Burst Master may return completions with incorrect traffic class and attribute fields set.
Resolution
The workaround is to correct the following RTL file, <install_dir>/ip/altera_pcie/altera_pcie_hip_256_avmm/rtl/altpcieav_dma_hprxm_rdwr.sv. You must add registers to record the correct traffic class.
After: logic [2:0] rd_tc;
Add: logic [1:0] rd_attr_reg;
Add: logic [2:0] rd_tc_reg;
Before the assignment statement:
req_id_reg <= req_id;
Add:
rd_attr_reg <= rd_attr;
rd_tc_reg <= rd_tc;
Under ///RXM Pending Read Interface change the first assignment statement to the following:
assign PndgRdHeader_o = {1\'b0, 4\'hF, rd_tc_reg, rd_attr_reg, 4\'hF, rx_dwlen_reg, req_id_reg[15:0], 1\'b0, rx_addr_reg[6:0], rd_tag_reg};
In <install_dir>/ip/altera_pcie/altera_pcie_hip_256_avmm/rtl/altpcieav_dma_hprxm_cpl.sv, the statement :
assign attr PndRdFifoData_i[48:47];
should read:
assign attr PndRdFifoData_i[47:46];
This issue is fixed in version 14.1 of the Quartus II software.
Updated 11 months ago
Version 3.0
