Knowledge Base Article
Sourced NativeLink script <Quartus Installation Path>/quartus/common/tcl/internal/nativelink/modelsim.tcl missing"
Description
Due to a problem in the Quartus® Prime Lite Edition Software version 22.1, you may see the below error message when you try to run the Nativelink simulation flow.
Info: Starting NativeLink simulation with Questa Intel FPGA software
Sourced NativeLink script c:/intelfpga_lite/22.1std/quartus/common/tcl/internal/nativelink/modelsim.tcl missing "
Error: NativeLink simulation flow was NOT successful
Resolution
To work around the problem, download and replace the qnativelinkflow.tcl file located at the <Intel® Quartus® Installation Path>/quartus/common/tcl/internal/nativelink directory.
Relaunch the simulation.
Download the qnativelinkflow.tcl
This problem is fixed beginning with the Quartus® Prime Lite Edition Software version 23.1.
Updated 6 months ago
Version 3.0No CommentsBe the first to comment
