Knowledge Base Article
Some CPRI IP Core Variations That Target an Arria V GX Device Do Not Achieve Timing Closure
Description
CPRI IP core variations with a CPRI line rate of 4.9152 Gbps or 6.144 Gbps that target an Arria V GX device may fail to achieve timing closure with the default Quartus II Fitter settings. Specifically, they may experience hold time violations on the PCS-PLD path.
Resolution
To achieve better timing closure results, perform one of the following actions:
- Add
set_min_delayassignments to overconstrain timing. - Try different Quartus II Fitter seeds.
This issue will be fixed in a future version of the CPRI MegaCore function.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
