Knowledge Base Article
Simulation Fails with PLL Clocks Out of Synchronization for UniPHY External Memory Interfaces
Description
During simulation, the PLL clocks lose synchronization.
Resolution
To work around this issue, follow these steps:
  1. In text editor open the design file and remove the following line: coverage exclude_file
  2. In the ALTPLL MegaWizard interface, turn on Create output files using the Advanced PLL parameters and regenerate the PLL ().
Updated 1 month ago
Version 2.0
