Knowledge Base Article
Simulation Fails with NativeLink
Description
When you use the NativeLink to run EDA RTL simulations for Verilog top-level file, the simulation fails and displays the following error message:
#**Error: (vlog-7) Failed to open design unit file “test.vo” in read mode. # No such file or directory. (errno= ENOENT)
Resolution
On the Simulation page, under EDA Netlist Writer settings, set Format for output netlist to VHDL. Then, replace the following codes of the generated <variation>.v file to a single-line code before running the NativeLink simulation.
Remove the following lines:
//IPFS_FILES:test.vo //RELATED_FILES:stratix_components.vhd,altera_avalon_sc_fifo.v,auk_dspip_avalon_streaming_controller_hpfir.vhd,auk_dspip_avalon_streaming_source_hpfir.vhd,auk_dspip_math_pkg_hpfir.vhd,auk_dspip_lib_pkg_hpfir.vhd,test_ast.vhd,test.v
Add the following line:
//IPSF_FILES:NONE
This issue will be fixed in future versions of the FIR Compiler II MegaCore function.
Updated 11 months ago
Version 3.0
