Knowledge Base Article
Simulation Fails When Enable Auto Error Correction Option Enabled
Description
For designs created with a version of the high-performance controller II (HPC II) earlier than 11.0, generation with the Enable Auto Error Correction option enabled on the Controller Settings tab will fail during simulation.
Resolution
The workaround for this issue is to add the CTL_ECC_RMW_ENABLED parameter
in the� dut.v wrapper file that instantiates the controller
wrapper file� alt_mem_if_ddr*_controller_top.sv, so
that CTL_ECC_RMW_EN is passed to the� controller wrapper.
This issue will be fixed in a future version.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
