Knowledge Base Article
Serial Digital Interface (SDI) Receiver Locking Problem
Description
You may encounter locking problem when any of these signals—enable_hd_search, enable_sd_search, enable_3g_search—is set to low for the SDI receiver in dual standard or triple rate mode.The locking problem is due to the corrupted recovered clock, caused by the improper handling of the transceiver reset.
Resolution
Set the enable_hd_search, enable_sd_search, and enable_3g_search signals to high when using dual standard or triple rate mode.
This issue will not be fixed.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
