Knowledge Base Article
SDI MegaCore Function Fails to Launch in Windows
Description
The SDI MegaCore function version 11.0 fails to launch in Windows if the installation path for the Windows-platform ACDS contains spaces.
This issue affects all SDI IP cores.
You cannot access the SDI parameters through the MegaWizard Plug-In Manager.
Resolution
Install the ACDS Suite in a directory that does not contain spaces in its path.
This issue will be fixed in a future version of the SDI MegaCore function.
Updated 11 months ago
Version 3.0
