Knowledge Base Article
SDI Audio MegaCore Function Designs with SOPC Builder Fail to Generate
Description
If you create an SOPC Builder design using any of the SDI Audio MegaCore functions, your design fails to generate and shows the following error:
Node instance "<sdi_audio_core_name>_0" instantiates undefined entity "<sdi_audio_core_name>"
Resolution
To generate SDI Audio MegaCore functions in SOPC Builder, follow these steps:
  1. Open a text editor and type the following commands: <QUARTUS_ROOTDIR>\ip\altera\<sdi_audio_core_name>\src\<sdi_audio_core_name>_hw.tcl
  2. Remove the following line: package require -exact sopc 10.0
Replace <sdi_audio_core_name> with audio_embed, audio_extract, clocked_audio_input or clocked_audio_output.
Updated 11 months ago
Version 3.0
