Knowledge Base Article
SDI Audio Extract MegaCore Function Shows Incorrect Behavior
Description
The SDI Audio Extract MegaCore function shows incorrect behavior when extracting the audio signal embedded in SD-SDI video format.
This issue affects all SDI Audio Extract configurations in SD-SDI video standard.
The extracted audio signal may be incorrect.
Resolution
None.
This issue has been fixed in version 11.0sp2 of the SDI Audio Extract MegaCore function.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
