Knowledge Base Article
Scaler II Generates Incorrect Output When Receiving Empty Packets
Description
The Scaler II MegaCore function generates incorrect output when it receives empty packets with only the header, start of packet (SOP), and end of packet (EOP) on the same clock cycle.
This issue affects all configurations that use the Scaler II MegaCore function.
The empty packets sent will be altered.
Resolution
None. You cannot deliberately send empty user packets through the Scaler II MegaCore function expecting unaltered outputs.
This issue will be fixed in a future version of the Video and Image Processing Suite.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
