Knowledge Base Article
Rounding error might cause clock edge misalignment in timing analysis
Description
If you use the TimeQuest Timing Analyzer to analyze a design that contains a noninteger phase shift relationship between the launch clock and the latch clock, timing analysis might fail. Rounding errors that occur during timing analysis cause periodic clock edge misalignments.
Resolution
Avoid specifying a phase shift that is not integrally divisible by the clock period.
Updated 2 months ago
