Knowledge Base Article
Riviera-PRO Crashes When Compiling Altera PHYLite for Memory Megafunction HDL File
Description
If, in the Quartus II software version 13.1a10 or later, you created an Altera PHYLite for memory megafunction example design and perform simulation using Riviera-PRO 2013.06, the compilation will result in the following errors:
# ALOG: Error: ASM2BIN_1297 Internal application error
- please contact Aldec Support.
# ALOG: Error: ALOG: Cannot add data to library.Resolution
If you are using Riviera-PRO, use Riviera-PRO 2013.06.SR1 instead of the supported Riviera-PRO 2013.06.
Updated 3 months ago
