Knowledge Base Article
Reset Synchronizer for UniPHY External Memory Interfaces May Cause Design to Fail Timing when generated in SOPC Builder or Qsys
Description
Systems generated with SOPC Builder or Qsys may fail timing closure due to paths that include a reset synchronizer.
Resolution
A workaround for this issue is to apply the following constraint in the TimeQuest Timing Analyzer:For SOPC Builder:
set_false_path -from {dut_sopc_top_reset_clk_0_domain_synch_module: dut_sopc_top_reset_clk_0_domain_synch*}
For Qsys:
set_false_path -from *:rst_controller*|*:alt_rst_sync_uq1| altera_reset_synchronizer_int_chain[*]
-to *:controller_phy_inst| *:memphy_top_inst|*:umemphy|*:ureset|*:ureset_*_clk|reset_reg[*].Updated 11 months ago
Version 3.0No CommentsBe the first to comment
