Knowledge Base Article
RapidIO IP Core Might Transmit Unreliable ackID_status Field in Status Control Symbol
Description
When the RapidIO IP core receives a valid packet with a specific
ackID value, the IP core should transmit a packet-accepted control
symbol for the packet before sending a status control symbol with
an updated ackID value in the ackID_status field. However,
the IP currently might incorrectly update the ackid_status field
value to the next value and send out the new value to the RapidIO
link partner in a status control symbol before transmitting the packet-accepted control
symbol for the packet with the original ackID.
Resolution
This issue has no workaround. You should ensure your design
does not rely on the value in the ackID_status field
of incoming control symbols.
This issue will be fixed in a future version of the RapidIO IP core.
Updated 2 months ago
