Knowledge Base Article
RapidIO II MegaCore Function User Guide Error in Avalon-MM Master Write Transaction Burstcount Calculation
Description
According to the RapidIO II MegaCore Function User Guide, in the table that lists the calculations for burstcount and byteenable on the Avalon-MM interface for a RapidIO write transaction with wrsize in the range of 4’b1100 to 4’b1111, the value of the RapidIO field address[0] affects the IP core output burst count on the Avalon-MM interface if the payload size is not a multiple of 16 bytes. However, this information is incorrect. The burstcount value for a write transaction with a payload size that is not a multiple of 16 bytes does not vary with the value of the RapidIO transaction address[0] bit. In all such cases, the value of burstcount is the number of 8-byte words in the packet payload, divided by two, and rounded up.
Resolution
This issue has no workaround. Ensure that you understand the expected burstcount value in this case according to the description above and not according to Table 4-8: Avalon-MM I/O Master Write Transaction Burstcount and Byteenable II in the RapidIO II MegaCore Function User Guide.
This issue is fixed in version 14.0 of the RapidIO II MegaCore Function User Guide.
Updated 11 months ago
Version 3.0
