Knowledge Base Article
quartus: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.3 and earlier, you might see this error message when launching the Quartus® Software GUI in the Red Hat* Enterprise Linux* 8 Operating System (OS). This is because the required shared library is not found in the OS system.
Resolution
To work around this problem, link the required shared library libncurses.so.5 from the available libncurses.so.6.1 by using the following command:
ln -s /usr/lib64/libncurses.so.6.1 /usr/lib64/libncurses.so.5
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 23.4.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
