Knowledge Base Article
Qsys: The generation path of a system copied to a new directory remain set to the original project directory
Description
If you create a new system and save it to a different directory from the original project directory, the generation paths remain set to the original project directory, even if Qsys is restarted.
Resolution
To correct the generation paths, delete the entry in the Path box of the Generation tab and press Enter. Qsys automatically populates the field with the correct generation path.
Updated 1 month ago
Version 2.0
