Knowledge Base Article
Qsys Generation Directories and the Temp Directory
Description
If you generate your Qsys system without a TMP directory set in your operating system's environment, you may see odd generation directories, for example, sopc_altera_pll1340162363051077 during generation.
Resolution
If you see directories in the format: <IP Core Name><System Time in Milliseconds> in your home directory during Qsys generation, verify that your environment is set up with correct TMP directory
locations for your operating system. Otherwise, you must manually remove these directories.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
