Knowledge Base Article
Qsys: Cannot add a new instance with the same name and interfaces as a disabled interface
Description
If you disable an instance in Qsys and then add a new instance with the same name and interfaces, duplicate connections might be created, resulting in an incorrect interconnect.
Resolution
Remove the instance (instead of disabling it) before adding an instance with the same name.
Updated 11 months ago
Version 3.0
