Knowledge Base Article
PLL Master Required for Simulation of PLL Slave for UniPHY External Memory Interfaces
Description
The example simulation design (generated in the <variation_name>_example_design\simulation folder) does not function correctly if the core is parameterized with PLL Sharing Mode = Slave, DLL Sharing Mode = Slave, or OCT Sharing Mode = Slave.
Resolution
The workaround for this issue is to ensure that a master instantiation is provided to drive the slave. To do this, follow these steps (a PLL example is shown):
  1. Generate a second, identically parameterized, IP core with PLL Sharing Mode set to Master.
  2. Manually instantiate the second IP core in the top-level file of the slave core’s example design, <variation_name>_example_design\simulation<variation_name>_example_sim.v.
  3. Connect the master and slave by following the usual PLL sharing flow.
Updated 11 months ago
Version 3.0
