Knowledge Base Article
"PLL base data rate" errors in Arria V Transceiver Native PHY IP Core PLL megafunctions
Description
In the 12.1 Quartus® II software release of the Arria® V Transceiver Native PHY IP Core, the megafunction generated design file displays a default phase-locked loop (PLL) base data rate of 1250 Mbps, regardless of the "PLL base data rate" user configuration in the GUI.
Resolution
This issue is fixed in the 13.0 Quartus II software release.
To workaround this issue in the 12.1 Quartus II software release, change the "Reference Clock Frequency" value in the GUI from the default "125.0 MHz" to any other value at least once before generating the IP core megafunction.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
