Knowledge Base Article
PCI Express Compiler Root Port Example Design Simulation Fails for Some Versions of ModelSim
Description
Root port simulation fails using ModelSim versions 6.6c_1 for the Linux operating sytem (OS) or 6.6d for the Windows OS.
This issue affects root port example design simulations when using ModelSim 6.6c_1 for the Linux OS or 6.6d for the Windows OS in release 10.0 of the PCI Express Compiler.
Resolution
To prevent this failure, add the -noimmedca option
to the vsim command in the runtb.do file.
Alternatively, you can update to version 10.1 of the PCI Express compiler.
This issue is fixed in version 10.1 of the PCI Express example design testbench.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
