Knowledge Base Article
Not all clock synchronization options are available in the DCFIFO MegaWizard Plug-In Manager
Description
In the DCFIFO MegaWizard Plug-In Manager, on page 3 under Are the FIFO clocks synchronized?, the option Yes, the clocks are synchronized, do not add clock synchronization latency. is not available.
Resolution
If you want to use this option, generate the megafunction with the No, the clocks are not synchronized, add latency to handle unrelated clocks. option. Edit the megafunction file generated and change the line:
dcfifo_component.clocks_are_synchronized = "FALSE" to
dcfifo_component.clocks_are_synchronized = "TRUE"
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
